Workflow v2026.3.4
New Features
Dynamic Display Images
Product and package thumbnails can now display the shopper's selected subject image using configurable dynamic display images. This gives customers a more accurate preview of what they're purchasing and makes shopping more intuitive. Learn how to set yours up here.
Fixes
Workflow
Quick Reprint
Image and background selection
Fixed an issue where studios could not select a different image or background during Quick Reprint — including on Build Your Own Package products where pose and background choices appeared locked or defaulted to the first option. You can now change images and backgrounds when creating reprint orders.
Price sheet changes
Fixed an issue where Quick Reprint failed with an error when the job's price sheet had been changed after the original order was placed — even when the products and pricing were unchanged. Reprints now complete successfully regardless of subsequent price sheet updates.
Large orders
Fixed an application error that prevented Quick Reprint from loading on large orders and blocked item editing during the reprint flow. Large orders can now be reprinted and edited without errors.
Images
Quick Image Filter counts
Fixed an issue where Quick Image Filter counts on the Images tab did not match the Sort & Filter results — including the "All" count. Quick filters now respect your global filter settings for Subject Images, Group Images, and Hidden Images, giving you accurate counts you can trust during culling.
Jobs
Quick Edit expiration date
Fixed an issue where the calendar month navigation arrows did not work when setting an expiration date in Quick Edit. You can now move between months without the date picker closing.
Designer
Drop shadow and outline on PNG images
Fixed inconsistent rendering where PNG images applied drop shadow before outline, while JPEG images applied outline before drop shadow. Both formats now render outline first, then drop shadow — so your designs look the same regardless of image type.
Product Rotation
Fixed an issue where designed products with a different orientation with the fulfillment orientation were not rotating correctly. For example, horizontal Designer products fulfilled by a lab as a product set as vertical are now properly rotated.
Shop
Background Selection
Fixed an issue where backgrounds were not displaying properly on mobile during package configuration.
