Workflow v2026.3.3
Improvements
Workflow
Job Dashboard
Added a quick-copy action for Job ID on the Job Dashboard, so you can grab the ID in one click when sharing it with your team or support.
Shop
Quicker Product Configuration: For individual products and single-pose packages, configuration is now faster by automatically selecting a default image for the shopper. The default image is chosen based on product eligibility, Buy Now selections, favorited images, and the subject's primary image. If other eligible images are available, shoppers can still change the selection at any time during configuration.
Fixes
Workflow
Number of images filter
You can now exclude hidden images when filtering subjects by image count. Pair this with your other filter options to quickly spot subjects who should only have one visible image online — a reliable check-and-balance step in your production workflow.
Subject search across sheet and detail views
Fixed inconsistent search behavior when moving between sheet view and detail view. Your search term now persists in both directions and appears in the search box on each view, so you don't lose your place or have to re-enter a subject ID.
Missing job images on V2 Designer products
Fixed an issue where orders could fail to render when a product's job image node had no matching image assigned in the job — including bulk orders that appeared stuck with no visible error. Orders now complete successfully; the missing image node renders blank while the rest of the product renders normally.
Print template PDF export
Fixed an issue where exporting a print template as PDF could stop partway through and crash due to a memory error on large exports. PDF exports now run through to completion.
Designer Image Grid on proof sheet products
Fixed an issue where creating a product with an Image Grid — including Proof Sheet layouts with single and separate pages (front and repeating pages) — locked the canvas and Image Grid settings so they couldn't be edited.
Shop
Cart Summary Thumbnails: Fixed an issue where shopper selected images were not displaying on the cart summary page for greenscreen galleries.
Multi Node Product Configuration: Fixed an issue that was preventing shoppers from being able to configure multi node products when selected from the side cart.
Add-On Pricing: Fixed an issue that was causing image option pricing to display incorrectly during configuration if the same image option had been previously added to cart.
