Workflow v2026.4
Workflow
Multi-subject order reprints
Reprinting multi-subject orders now works as expected. All subjects included in an order are correctly carried through during reprints, making it easier to produce accurate orders. If items are removed during the process, they remain grouped under the correct subject so your cart stays organized.
Duplicate print templates
We've fixed an issue that could cause the same Product Designer design to appear multiple times when adding print templates to a job. Designs now appear only once, making template selection simpler and ensuring the correct products are sent for printing.
Improved Product Designer sync
We've resolved an issue that could prevent new and existing Product Designer products from syncing successfully. Products can now be added to categories and synced without interruption.
Shop
Image selection
We've fixed an issue where group-only designs inside Build Your Own packages did not always correctly default to the appropriate image.
Featured packages Dynamic Display Images
Dynamic Display Images now display on featured packages, helping customers see the right product preview.
Consistent Quick View
The Quick View window now shows the same Dynamic Display Image as the main product list, providing a more consistent shopping experience.
Improved image option labels
We've fixed an issue where longer required image option names were not displaying correctly during checkout on desktop. Option names now display cleanly across breakpoints.
Faster loading product cards
We've improved how Dynamic Display Image thumbnails load on product cards. Product information remains available while images load, improving navigation and accessibility.
