Workflow Latest Release v2026.4.0-eap.1
Improvements
Workflow
Archive and activate confirmation toasts
Success toasts now appear when you archive or activate across more of Workflow — including Jobs, Price Sheets, Stage Templates, Cart Templates, Custom Forms, Print Services, AI Profiles, and Image Attributes. You’ll see clear confirmation (for example, “Successfully archived” / “Successfully activated”) instead of a silent update.
Fixes
Workflow
Marketing
We’ve fixed an issue that caused the subjects with a group image audience segments to include subjects assigned to a group without an image.
Custom Forms archive and delete
Fixed an issue where archiving or deleting a Custom Form looked like nothing happened until you cleared your local cache or logged out. The list now updates immediately — archived forms show as archived, and deleted forms are removed from the table.
Quick Reprint image options
Fixed an issue where image options (such as retouching) were not saved on Quick Reprint orders — especially after the job’s price sheet had changed. Image options now carry through to the reprint cart, the saved order, and the customer receipt, even when the current price sheet no longer matches the original.
Quick Reprint lab personalization
Fixed an issue where product personalization (lab text and other product options) was missing from the customer invoice and sometimes did not reach the lab for printing on Quick Reprint orders.
Shop
My Photos and Yearbook in the footer
Shoppers can now reach My Photos and Choose Yearbook Pose from the footer, so they don’t have to scroll back to the top—especially helpful on mobile.
Package display images
Packages without a dynamic or custom display image now use the correct fallback preview instead of inheriting an image from a product inside the package.
Cropping
We’ve fixed an issue that caused the adjust photo option to fall off screen with some product previews.
