Lab Link Latest Release 2026.1.1.115
Improvements
Shipping & Tracking
  • Shipping Export Report: The report now exclusively includes orders that have been printed, preventing unprinted orders from cluttering your export data.
Printing & Output
  • PDF-to-JPG Conversion: Added support for converting condensed PDF outputs directly into JPG format.
  • Cleaner Receipts: Removed redundant job names and IDs from condensed receipt layouts for a cleaner look.
Settings & Usability
  • Printer-Level Sort Control: You can now configure and manage the Printing Sort Order directly at the individual printer level, instead of a global setting.
Fixes
Printing & Output
  • JPG/PNG Writer Size Fix: Resolved an issue where exported JPG and PNG files were not saving at the specified dimensions.
  • Bulk Summary Fix: Fixed an issue that caused bulk summary reports to cut off after the first page.
  • Noritsu QSS Retries: Hardened retry logic and failure handling for Noritsu QSS printing workflows.
  • Shared File Fix: We’ve resolved an issue where refreshing orders on one workstation could trigger false error messages (such as an "Invalid Order JSON" alert) if another workstation moved or processed the order file at the same time.
