Workflow Latest Release 2 v2026.4.1-eap.2
Improvements
Workflow
Select all / deselect all
Checkbox groups in Subject Sheet view and the Print Job wizard now select and deselect predictably. You can clear a full selection in one click instead of unchecking every item, and clicking beside the list no longer toggles everything. First Name stays visible in the Subject Sheet so the grid never goes empty.
Fixes
Workflow
Capture search from Subjects
Fixed an issue where a search on the Subjects tab carried into Capture and couldn’t be cleared — hiding other subjects and leading to duplicates on picture day. Capture now opens in its own default state, with no inherited search.
Order error banner
Fixed an issue where failed-order error messages stacked and pushed the orders table off the screen, blocking other work. Multiple failures now collapse into one line (“N orders failed to sync”) with Show details; a single failure still shows inline. The banner clears when orders sync or are deleted.
Quick Reprint product options
Fixed issues with product options on Quick Reprint: the Options tab staying available after you save, reprints completing after options are removed, and adding options that weren’t on the original order.
Shop
Designer Fonts
Fixed an issue where adding products with different fonts stopped products from being added to the cart.
Multi-gallery ordering from studio links
Fixed an issue where shoppers who started from a studio URL could not switch between linked galleries to continue ordering across subjects.
Designer image attributes
Fixed an issue where image attributes mapped in Designer were not consistently carrying through in Shop, causing products with matching tagged images to appear unavailable.
Pose package limits
Fixed an issue that was causing packages with a set number of poses to occasionally allow shoppers to select more poses than the product allowed.
Display image proportions
Fixed an issue that was causing display images to appear stretched or compressed, including in Safari and on iOS.
