Page Numbering Options
Page Number Position
To change the position of your page numbers (bottom center or bottom outside), click on any page number in your book, then drag the page number to the new position. All other page numbers in your book will follow along to the same position.
Page Number Styling
To change the font, color and other style attributes of your page numbers, click on a page number to access the font tool bar. Should you only want to change the styling for a single page number, toggle the last button on this tool bar so changes will only apply to the currently selected frame.
Tip: Use a contrasting outline on your page numbers to ensure they will be visible regardless of the background color behind them.
Disabling/Enabling page numbering
Click on the top right menu icon.
Choose Project Management.
Under the Project Settings tab, use the Hide page numbers toggle to turn page numbering on/off, then save your selection.
