Candid Pages: Images & Shapes
Understanding Frames
Pages are designed in the editor using images, shapes and text. Photos, clip art, shapes may be dragged from the preview pane on either side of the page to build your page composition.
Once an element is added to the page, it appears in a frame that may be selected. Selected frames display a blue border with handles around them.
Adding Images & Shapes
To add a photo to your page, choose one of the Candid image folders option on the right side pane. Locate an image inside the folder, then drag it onto your canvas.
The image will appear inside a frame, where you can adjust its position, size, shape and other attributes.
To add an empty image frame or a shape, choose the Design Elements option on the right side pane. Drag your choice of element to the page.
Image Resolution Warnings
Resolution warnings are triggered when falls below your publishers dots-per-inch (DPI) tolerance. DPI is a measure of the number of available pixels spread over the dimensions at which the image is sized.
Low resolution images are tinted red to help avoid quality issues with your printed book.
If you choose not to replace or resize a low-res image, it will not print with the red overcast, but will most likely show blurriness or pixelation.
Try resizing low-res images to a smaller dimension on your page to increase their DPI. Be particularly mindful if you receive a warning for an image on your cover or a feature image on an interior page, such as an enlarged portrait image or your school logo.
The Image & Shape Frame Toolbar
When you select an image or shape frame on your page, a toolbar will appear to provide editing options. The complete toolbar is shown below, but some features may be hidden (eg. an image frame with no photo in it, shape frame cannot flip its contents, etc.)
1. Frame order (move up/down)
5. Flip horizontal/vertical
9. Image tagging
2. Border & shadow
6. Text caption
10. Manual position & size
3. Image effects
7. Apply effects to all elements on page
11. Lock in place
4. Image cropping
8. Duplicate
Tip: Change where the toolbar is positioned on your page from your settings options. Click on the menu in the top right corner of the page. Choose My Settings to access the Toolbar Location dropdown: keep the toolbar floating above the selected frame, or lock it to the top or to side of the page.
Moving & Resizing Frames
To move a frame to a new position on your page, simply click down on it and drag it
To resize a frame, pull on any of the blue handles around the frame’s edge. The frame will resize proportionally when you resize it on the canvas directly, making the frame larger or smaller.
Cropping Images Within Their Frame
To change an image's cropping within its frame, access the cropping tool. Turn off “Lock Aspect Ratio” to change the shape of the frame itself.
Setting a Frame Position With Dimensions
To precisely resize or position a frame, use the Edit position and size option on the toolbar to set a numerical value for exact page coordinates or frame height/width size.
Swapping an Image in Its Frame
If you want to drag an image on top of a frame to replace it, configure how you would like image swapping to work. Access the menu icon in the top right corner then go to My Settings. Select one of the three options for candid swapping: always replace an image in a targeted frame; always add a new candid frame on to the page (never swap) or ask every time. The last option provides you with the most flexibility, particularly if you are adding a lot of images to a page.
If Replace or Ask every time is selected, a new image may be dragged on top of an existing image frame to replace it.
Rotating a Frame
To rotate a frame, click on the rotation handle and drag it to spin the frame.
Duplicating a Frame
To duplicate a frame, select it, then access the Duplicate button on the toolbar. Make an exact copy of the frame on the current page or add the copy to another selected page. You can also move the current frame to another page by adding a destination page number.
Locking a Frame
To lock a frame's position or prevent the image from being swapped, click on the lock icon. Click on the lock icon over the image frame to unlock it.
Deleting a Frame
To delete a frame, selected the frame and hit the delete key on your keyboard.
You may also click the red X button on the floating toolbar to remove the frame, leaving the frame in place.
Flipping an Image in Its Frame
To flip an image horizontally or vertically within its frame, use the flip tools.
To move a frame up or down the layer stack, click on the up or down arrows on the tool bar. Each click moves the image up/down one position.
Adding a Border
Add a border around your frame in your choice of colors and widths.
Turn on Size Scaling to resize the border proportional to the frame size on the page. Larger frames will have thicker borders, smaller frames will have thinner borders.
Turn off the border by clicking the X in the top right corner of the border editor.
Adding a Shadow
Add a shadow to your frame, in your choice of color, depth (spread), intensity, scale and rotation. Image scaling is also available, so larger image will show larger shadows, etc.
Changing a Frame's Shape
To change the shape of a frame, access the Masks >Shapes option from the left-side pane.  Drag any of the shapes onto the frame to apply it.
Decorative Effects
The toolbar offers an array of decorative effects which may be used in combination with one another.
  • Invert the colors of your frame (image or shape fill color).
  • Greyscale transforms the frame to black & white.
  • Blur out an image for an interesting background effect.
  • Opacity changes the transparency level of the frame.
  • Saturation makes color more or less intense.
  • Contrast adjust the relative value between light and dark areas.
  • Brightness lightens/darkens the image.
  • Hue shifts the colors.
Tip: Be very careful when adjusting brightness, contrast, saturation and hue effects when correcting images – if your monitor is not professionally color-calibrated, you may find your images do not appear as intended on your printed pag
