Portrait Page Design
Portrait pages feature labeled photo grids organized by grade, classroom, or staff groups. Creating these pages in Captura is as easy as dragging and dropping a grade or classroom group onto your page, then customizing it as you like.
Note: Portraits are referred to as subjects and portrait groups (classroom, grade) are referred to as batches.
Portrait Page Workflow
Follow these steps to design your portrait pages:
Import your portrait package into Captura Yearbook by following the steps in the Portrait Import & Management article.
Review and correct to your portrait information by following the steps in the Managing Portrait Data section.
Launch the page editor, choose a page, then flow a portrait group onto the page following the instructions below.
Customize your portrait page grids to your liking – change size, arrangements and other features.
Portrait Page Structure
B. Page Title – can contain auto-generated text or custom text C. Portrait Images – added to the grid using the Portrait Wizard D. Labels – display the name, salutation or job role of a person and are placed below the portraits or to the side of the grid |
Adding a Portrait Grid to a Page
After importing your portraits and managing the data as described above in Steps 1 & 2, you may flow batches (groups) individually to your pages. Navigate to a page where you want to add a portrait grid.
Drag your selected batch directly from the top of the editor onto the page. Confirm that you want to add the batch to the current page. A portrait grid in the default size will appear on the page, flowing onto additional pages if required.
Batches that have been added to the book will be highlighted above the page.
If you choose to add keep each group on its own page, continue to drag the batches from the top of the page onto new pages.
To add the next group to the bottom of the same page, drag another batch to the bottom of the page. Confirm that you want the new batch to begin right after the first batch. The new group will flow on the next line following the first group
Removing a Portrait Grid
To delete a portrait grid from a page, click on the page gear wheel then choose Make Candid from the page menu options. The grid will vanish, and the batch (portrait group) that was on the page will appear as unused at the top of the page.
Changing the Order of Portrait Pages
Portrait pages may be dragged in the page previewer. Candid pages may be inserted in between portrait pages.
Portrait Grid Customization
Grid Size PresetsHover over the portrait grid to choose a preset size option – small, medium or large portrait images. | |
Portrait Frame ShapePortraits appear in a standard rectangle shape by default. To change the shape of all portrait frames on a page, access Masks > Shapes on the left-side preview pane. | |
Drag one of the shapes onto a portrait grid. The entire portrait set will update to the new shape. | |
Class Layout OptionsAccess Class Layouts on the right-side pane. Layouts may be dragged onto a page before or after the portraits have been flowed onto the page. | |
Layout options include feature image position, label position and custom row/column arrangements. | |
Label PositionClass layouts include options to place labels under the portraits or next to each row. Drag your choice of class layout to align the labels on your page. | |
Class BehaviorsPortrait grid customization options are available in the right side pane’s Class Behaviors area. | |
Subject NamesConfigures the way the name labels are displayed with Subject Name: first name, last name, initials, overflow rules for long names, grade, job titles, custom and no label options are available. | |
Teacher NamesSet special rules for featured staff labels on portrait pages. Choose to add salutations and job titles, or include or exclude first names | |
Page TitlesConfigure what text will be included on the portrait page title. Use the batch name (group name) and combinations of the teacher name and grade. Click into the page title to customize it further. Edit the tags within the frame and/or change the font properties. | |
Cell AlignmentSets the rules for the last row of the portrait grid - aligned to the edge or gutter, right or left, or centered. | |
Side Padding and Top/Bottom PaddingChanges the grid inset margins. Move your grid away from or closer to the safe margins. Note that increasing the side padding may cause your portrait page to flow over to the next page. | |
Cell paddingSet the spacing between portraits: tight, medium or large spaces between the images. | |
Page BehaviorsTurns page numbers on or off the portrait page, and enable color versus greyscale images. |
Applying Portrait Settings to Other Pages
To copy settings from one portrait page to another, access the page settings menu then choose Apply Layout to All option. Select what elements to copy and which batches (groups) to update.
Decorating Portrait Pages
Like any other page, portrait pages may have a background, but try to keep the design simple to ensure that labels are readable.
Candid images and clip art may also be added. Note that images placed on top of a flowed portrait page will “run away” to clear space for the decoration. Send the image to the back layer of the page if you don’t want to create spaces in your grid
