Workflow Latest Release 3 v2026.4.1-eap.3
Improvements
Workflow
Users list
Settings → Users is rebuilt as a denser, searchable grid with pagination, column controls, quick copy, refresh, and multi-select bulk delete. Filter by role, created date, or job — including users assigned to a job and users who can open every job — and use Quick Edit to update roles and job access for many users at once, so you can manage a season’s users without opening each record one at a time.
Fixes
Workflow
Bulk job import without expiration
Fixed an error that blocked Bulk Job Import when expiration region or date was blank. You can import jobs without expiration dates when you don’t want jobs to expire.
Offline printing with existing images
Fixed offline printing failing when a subject already had synced images from a prior session — even if a new image was set as primary. Offline print now works whether the subject is new or already has images on file.
Image cropping performance
Improved cropping on the Images tab so long cropping sessions are less likely to hang with spinning previews that force a restart.
Designer
Toggle option description spaces
Fixed an issue in Designer and Workflow Lab where you couldn’t type spaces in a toggle option description. Spaces now type normally as you write.
Designer layer order on sync
Fixed layer reordering that didn’t save on the first sync and required a second reorder. Your layer order now saves on the first sync.
Collection range resets
Fixed an issue where editing any field on a Designer collection (for example, price) reset the collection range to 1–1. Your set range now stays in place when you update other collection fields.
Large image and banner print renders
Fixed print and order renders that went black, dropped layers, or failed on large job images and oversized products (including large banners). Prints now match Designer preview more reliably by sizing images appropriately for the canvas instead of loading full native resolution into print.
Shop
Dynamic display image backgrounds
Fixed an issue where backgrounds were missing from system-generated display images in Quick View and product details.
Mobile product descriptions
Fixed an issue where image carousels could overlap package or product descriptions on mobile devices.
Improved error recovery
Shoppers now see helpful recovery options if an unexpected error occurs instead of a blank page.
Screen-reader support
Improved screen-reader handling for studio logos, product images, promotional content, empty states, and decorative images throughout Shop.
