Workflow Fall Hotfix v2026.4.2
Fixes
Image cropping performance
Improved cropping on the Images tab so long cropping sessions are less likely to hang with spinning previews that force a restart.
Capture search from Subjects
Fixed an issue where a search on the Subjects tab carried into Capture and couldn’t be cleared — hiding other subjects and leading to duplicates on picture day. Capture now opens in its own default state, with no inherited search.
