Exporting Data with Captura Workflow
Learn about the different exports available in a job using Captura Workflow
How do I make export data or make common exports like PSPA, PowerSchool, Synergy, etc.?
In a job, click on Tools > Export and click +New Export to get started:
Using a Subject Data & Images export, you'll configure various settings in different sections of the export to meet your needs.
❗Unsure what settings are needed? Ask your school for a sample export to compare, or contact support for help❗
How do I save my custom export?
At the final section, click Save in the top-right corner apply a name to the export:
The named export is now available in the export selection menu:
Step-by-Step Custom Export
  1. Go to the Export Tool
    • Navigate to Job > Tools > Export.
  2. Choose Export Type
    • Select Subject Data and Images Export.
    • Click the radio button for Subject Data and Images.
  3. Set Export Destination
    • Enter the folder path where you'd like to save your exported files.
  4. Name Your Files
    • Provide relevant information for the file name and file type.
  5. Select Subjects
    • Choose to export all data and images, or click Filter Subjects to select specific groups.
  6. Sort Your Export
    • Choose how you'd like the images to be sorted (e.g., by name, ID, or date).
  7. Filter Images (Optional)
    • On the Images page, apply additional filters to narrow down your selection
    • Click Modify Images.
    • Adjust:
      • Size
      • Zoom
      • Crop
      • Color Correction
  8. Add a Background
    • Check the Add Background box.
    • Choose the folder where your background is stored.
    • Note: Green screen must be enabled to see this option.
  9. Finalize Naming
    • Choose how you want your images to be named (e.g., subject name, ID, custom format).
  10. Export
    • Click Export to complete the process.
Does Captura Workflow come with any pre-built templates?
Captura Workflow comes with different pre-built exports based on your membership:
Shopping Cart Only Members:
  • QR Code export (used for promoting online ordering)
  • Subject Data & Images
  • Gallery Visitor Emails
Smart Workflow Members:
  • QR Code export (used for both sorting images and promoting online ordering)
  • Subject Data & Images (flexible export to create, save and run custom exports)
  • Barcodes (30up)
  • Barcodes (8up) 7x10
  • Cume Stickers
  • Mugbook
Need more help?
Start a chat or book a meeting with Captura Product Support for export help!
