Using Job Data tools in your Job Settings
The Job Data section contains tools for managing and maintaining the data within a Job.
From here, you can review or remove imported data, organize images, reset primary images, group subjects, or revert a Job back to its last synced version.
Some of these tools permanently modify or delete data, so it's important to understand what each one does before using it.
To access the Job Data tools:
  1. Open your Job.
  2. Navigate to Job Settings.
  3. Select Job Data.
The Job Data section provides several utilities for managing subjects, images, and other Job data.
💡 Pro Tip: If you've accidentally imported the wrong subjects or images, use the overview tools to remove the incorrect data before importing again.
Available Job Data Tools
The following tools are available within Job Settings > Job Data.
Tool
Subject Overview
Displays the total number of subjects in the Job and provides the option to delete all subjects along with their assigned images. Useful if incorrect subject data was imported.
Images Overview
Displays the total number of images in the Job and provides the option to delete all images. Useful if the wrong images were imported.
Revert Job
Restores the Job to the last version successfully synced to the Captura Cloud, removing any un-synced local changes. Helpful if changes were made by mistake or the Job won't sync.
Organize Images
Sorts all images alphabetically using their original filenames across every subject.
Set Primary Image
Automatically assigns or reassigns the primary image for every subject using one of several selection methods.
Group Subjects By
Creates subject groups automatically using captured subject data and assigns subjects to those groups.
Set Primary Image Options
When using Set Primary Image, you can choose how the primary image is assigned for every subject.
Option
First Image
Uses the first image in each subject's gallery.
Last Image
Uses the last image in each subject's gallery.
Newest Image
Uses the image with the most recent EXIF timestamp.
Oldest Image
Uses the image with the oldest EXIF timestamp.
When Should You Use These Tools?
Tool
Common Use Case
Subject Overview
Remove incorrect subject imports before importing new data.
Images Overview
Delete incorrect image imports before uploading the correct files.
Revert Job
Undo un-synced local changes or recover from synchronization issues.
Organize Images
Keep image order consistent using original filenames.
Set Primary Image
Quickly assign a consistent primary image across every subject.
Group Subjects By
Automatically organize subjects using available subject data.
Important: Tools that delete subjects or images permanently remove that data from the Job. Make sure you're deleting the correct information before proceeding.
Q: Where can I find the Job Data tools?
A: Open the Job, navigate to Job Settings, then select Job Data.
Q: What does Revert Job do?
A: Revert Job removes any local changes that haven't been synced and restores the Job to the last version stored in the Captura Cloud.
Q: Can I delete all subjects or images?
A: Yes. The Subject Overview and Images Overview tools both include options to remove all subjects or all images from the current Job.
Q: What does Organize Images do?
A: It sorts every image in the Job alphabetically using the original filename.
Q: How does Set Primary Image choose an image?
A: You can choose to use the first image, last image, newest image (based on EXIF timestamp), or oldest image for every subject.
Q: What does Group Subjects By do?
A: It uses available subject data to automatically create groups and assign subjects to those groups.
