How do I fix missing images in a job?
Learn how to tell Captura Workflow to look for and upload missing images in your Job from your device to our cloud
What does it mean when my Job has "missing images"?
There are two phases to adding images to Captura Workflow (and the IQ cloud):
  1. Adding images from a device to a job.
  2. Syncing that data from your local device to our cloud.
The second phase (syncing) is what makes your data available online for clients and available on any computer you use Captura Workflow.
Every now and then, strange things occur, and the data doesn't make it all the way through. As a result, Captura Workflow may be aware that there are subjects with images, but we don't have the actual image stored in our cloud for reference, which is why you're seeing this message:
❗Subjects assigned missing images CANNOT access their online gallery❗
How do I tell which images are missing?
You can tell if a Job has missing images because the title will be listed in red:
Jobs that have missing images also have an additional filter option in the Subjects tab. You can also use the Images tab within the job to filter for Missing Images. Apply the filter to narrow your view to affected subjects only:
❗Need more help? Start a chat with us now❗
Missing Images Filter — No Results Found?
If you've applied the "Missing Images" filter and no subjects appear, it's likely that the missing image is part of a group photo. Group images are not tied to individual subjects, so they won't show up in the filtered results.
To resolve this:
  1. Navigate to the Groups tab within your job.
  2. Look for any image that appears missing or corrupted.
  3. Re-upload the correct group image to restore access.
Once the image is restored, affected subjects will regain access to their online galleries.
How do I restore or delete missing images?
After closing the "missing images " message, you can restore or delete the missing images by going through these step - Job's Settings > Job Data > Missing Images:
Action
Behavior
Restore Missing
  • Captura Workflow will ask for a folder that contains the images currently missing in a job.
  • Captura Workflow will check the filenames of the missing images against the ones in the folder you've chosen and restore them if they match. Just be sure that the names align within the folder you've picked.
  • Affected images sharing a filename with at least 1 other image are skipped.
Deleting Missing
  • Captura Workflow will delete all missing images in the job.
