Getting started with the Images Tab
Learn how to take advantage of the Images tab to apply quick, non-destructive crop, color, attribute selection and quality assurance.
What is the Images tab?
The Images tab directs attention to the images uploaded for your job. Here, you can review and edit single or multiple images within a Subject Job. This tab is exclusively accessible to Smart Workflow members. To access the Images tab, click on the Images icon in the Navigation Bar.
Toggle between Grid View and Detail View using the new View Selector in the top bar of the Images tab.
⚠️ Caution
Image Size Limit
If your images exceed 4000 × 6000 pixels or 25mb, image services will not run.
This includes AI edits, crops, and other processing tools.
Resize images before uploading if they exceed this limit.
Detail view for culling and cropping - NEW!
The Image Detail View is a new layout option that allows you to enlarge images while applying culling actions, image attributes, and crops — all in one place. It’s perfect for production users who want a closer look while making important image decisions.
Selecting Images
Click on an image to select it. You can select multiple images in this tab using one of two methods:
Select multiple images: Hold Ctrl (Cmd on Mac) + click to select individual images.
Select a range of images: Hold Shift + click to select a range of images.
After selecting your desired images, you can use the drop-down toolbar to download, hide, delete or reassign your selected images to a different subject.
Reverting Images
Selecting images in a Green Screen job will allow you to revert an extracted PNG back to the original .jpg version. Select the image(s) you'd like to revert and click Revert Image in the toolbar.
Reviewing Images
Upon opening the Images tab, you'll see a grid containing all Subject Images in the Job. Each subject has a different colored bar running underneath their images to easily determine at a glance where a subject's images begin and end. Click on the + button to see all hidden images (if applicable).
Click the ellipses button (...) to open the selection tool. Utilize the checkboxes to designate an image as primary, for the yearbook (if relevant), or to hide it.
Pro Tips: The Orders Icon next to the Subject name indicates that this Subject has had orders placed in the Job. You can also select the Primary Image attribute by clicking on the Gold Star in the top-right corner.
Utilize the filter button beside the search box to refine your display of images and subjects in the grid. Explore all the available filter options to acquaint yourself with the various viewing possibilities.
Pro Tip: The image count in the top-left shows total images in your current view. That number will adjust automatically as filters are placed on your default view
Use the slider in the top-right corner to adjust the size of the images in the image grid. Play around with the sizing to find the view that's right for you!
Editing Images
Click on the Edit button in the top-left corner next to the image count to switch from Review mode to Edit mode.
Navigate editing tools by selecting the tabs located on the far-left pane of the screen.
Color
Make manual adjustments to the brightness, contrast, hue, saturation, and color balance of images.
Crop
Crop images based on inputting x and y coordinates and zoom.
Head Size
Automatically apply a crop based on head size using facial detection of features.
AI Image Editing
Suite of AI pretouch image editing features including AI Crop, AI Color Correction, AI Background Extraction, AI Face Retouching, AI Glass Glare Removal, AI Teeth Whitening, and AI Braces Removal.
Learn more about these features here.
⚠️ Important: When running multiple services back‑to‑back, make sure you’re working with the latest data. Refresh or sync before starting your next service.
Applying Changes
In the subsequent pane, you can indicate whether the edits should be applied to a single image, a filtered image set (if applicable), or all images.
Click on the apply button to apply the edits. Use the reset button on Color, Crop, or Head Size if you made a mistake and need to remove edits and restore the original version.
During the image editing process, utilize the toolbar at the bottom of the central pane to activate guidelines, implement standard crops, or display the image file name. Additionally, you can click and drag to manually position the image according to your preferences.
Once you click Sync you versioned image will be available.
Download and Replace Images
Utilize the download and replace features to export images from Captura Workflow for editing with external tools or software such as Adobe Photoshop. After completing your edits, simply click the Replace button to effortlessly substitute the relevant images in the job with your edited versions. In this situation, we recommend preserving your images as the optimal choice.
Pro Tip: Please be aware that the replace feature operates by aligning the image filename in Captura Workflow with the file name in the folder housing the replacement images. If Captura Workflow cannot locate the corresponding image filename in the job, it will bypass the image in the folder.
