Download Captura Workflow and Workflow Lab
Choose your operating system below, then click the appropriate download link to install the latest version of Captura Workflow or Captura Workflow Lab.
Captura Workflow
Operating System
Download
Windows 11 (64-bit)
Windows 10 (64-bit)
Download for Windows
macOS 13 Ventura or newer**
Download for Mac
Operating System
Download
Windows 11 (64-bit)
Windows 10 (64-bit)
Download for Mac
*Windows 32-bit systems are not supported.
**Macs built in 2010 or earlier are not supported.
ARM-based systems
Workflow is not officially supported on ARM-based systems but can still run using emulation.
Note: You may experience minor performance delays while using Workflow through emulation.
Installing updates
Workflow receives automatic updates outside of the Fall season.
When an update is available, click Update Now to begin installing the latest version.
If you'd rather update later, select Later and Workflow will install the update automatically the next time you close the application.
For IT Professionals
If Workflow will be installed on a domain-controlled workstation or managed network, please ensure the following requirements are met before installation.
  • Allow network traffic to *api.imagequix.com.
  • Allow Registry Edit access for the user account to:
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\806c13e0-1bb7-5fc0-b1ef-6593ede2ca5e
Note: If either of these requirements is not met, Workflow may only display a white screen when opened.
Workflow requires access to modify this registry location during installation and future updates.
If you need additional assistance, contact us: support@captura.io
Minimum device requirements
  • Intel i7 12th Generation Processor, Apple M1/M2/M3, or equivalent
  • 16 GB DDR4 RAM
  • 128 GB SSD
  • 1920 × 1080 display
