Quick Menu
Selecting a checkbox next to an order in Fulfillment shows the Quick Menu:
The available actions change switching between Print Services and Image Services.
Print Services Quick Menu
This menu lets you make various changes/updates to order(s), such as:
  • Reset Order
    • Sends order back to studio to edit/correct.
    • Required follow-up prompt to confirm and complete reset.
  • Remove Lab Order ID
    • Removes Lab Order ID currently applied to order.
      • Orders receive a Lab Order ID when set to Processed.
      • Remove the Lab Order ID to have it generate a new ID (and re-download) when reprocessed.
  • Edit Status
    • Order status starts with New status.
    • Order status is changed to Processed when printed.
    • Order status is changed to Processing when order printing failed.
    • Order status can always be manually set
      • Example: Changing an order status from Processing to Shipped
  • Export
    • Export the Smart Feed without printing the order
  • Print
    • Print selected orders
Image Services Quick Menu
  • Revert Images
    • Removes the serviced image from the selected orders.
    • Resets the selected image service orders status to New.
  • Download
    • Downloads images from selected orders to begin image servicing
