Downloading & Installing Flow
Where do I get Flow?
Click the button below for the latest build of Flow! We recommend using Windows 10 with 64-bit systems. 32-bit systems are not supported.
How do I install Flow?
1. Right-click on the installer and select Run as Administrator
2. Follow the install prompts
3. Once finished installing, right-click on your Flow® icon on your desktop
4. Select Properties
5. Under your Compatibility tab, check off Run this program as an administrator
6. Click Apply then OK
