Flow Manual
Captura's FLOW User's Manual
Flow® is a capture program that gives you the capability to match student images and data. It has a robust layout creator that allows you to build and print different items such as ID cards, proof sheets and order forms. Use the powerful Green Screen tools in Flow® to knockout and apply your own backgrounds. When all of your images and data are matched and packages are entered, you can send your order directly to your lab.
This document will walk you through installation, getting set up, starting a job, and all of the other steps necessary to create and submit a Flow® project.
