Flow Capture Screen Issues
Missing windows in the capture screen
Reset Capture Screen Layout
Go to: C:\ProgramData\Flow\Config and delete the following files ONLY: DefaultDockSettings.xml and DockSettings.xml
Don’t see the Overlay box or when check no overlay appears
Hide the taskbar on the Windows screen by going to the Taskbar settings and clicking always hide.
There are no overlays in the Overlay folder.
Layout Preview window is not showing
Can’t save a subject’s record
Missing first name or last name or both
Missing required information
