Flow Hardware Requirements
Flow® Hardware Requirements
Capture Station
CPU - Intel i7 or above
​RAM - 6GB +System - 250GB (SSD)
​Storage - 500GB Hard DrivePorts - USB 3.0+ ports (4 available)
​Internet - Fiber or Business Class Cable
​Video - Nvidia or ATI GPU with 512MB+ RAM
​Resolution - 1366x768 minimum (1920x1080 recommended)
​OS - Windows 8.1 or 10 64bit
Production Workstation (Flow Master)
CPU - Intel i7 or above (Desktop)
​RAM - 12GB +System - 512GB (SSD) System
​DriveStorage - 1TB 7200rpm Hard DriveNetwork - Gb+ Ethernet
​Video - Nvidia or ATI GPU with 1GB+ RAM
​Resolution - 1920x1080 recommended
​OS - Windows 8.1+ 64bit
  • A quality Internet connection is required to Submit Orders and upload Projects/Online Galleries. The following website will give you and your lab a good idea where you are and where you should be in respect to Bandwidth. UPLOAD bandwidth is the most important. Check your Speed here: Speed Test
