Enhance Cropping
Our cropping tool uses perceptual head sizing to ensure a consistent crop across subjects in a job. We offer both default yearbook sizing (profile named “PSPA”) as well as the ability to build out custom crops through our Simple Profile workflow (tutorial here)
When building out a custom crop, ensure you are using the “Simple” profile workflow where you may upload 5 images to preview the crops on, before running a job. This will allow you to build out consistent crops, whether they are headshots, ¾ length, or full body.
How to use it? Select PSPA from the profiles dropdown menu, or upload your own images to create a profile in the simple profile workflow.
🪄Our best user tip? Use the simple profile creation workflow to build out custom crops and dimensions for each of your workflows.
