Creating Profiles with Enhance
How to create custom profiles and feature combinations, including crop and extraction outputs.
Profiles are used to customize file output, crop dimensions, extraction configurations and to combine multiple Enhance features at once!
*Please note, any features toggled on for a profile will be applied to all images in a job*
Creating a custom profile:
Click the “Profiles” tab on the left-hand panel of
Select "Advanced" or "Simple"
Simple profiles are best when creating a custom crop as you are able to upload your own sample images and crop based on those.
Advanced profiles are best when you would like to create a quick combination of features and do not need to customize crops
Provide a name —> Continue
Toggle on the features you would like to use. You may turn on as many features as you like
If a toggle is green, the feature will be used in the profile.
If a toggle is grey, the feature will not be used in the profile.
Click “Create Profile” on the bottom right
Specific feature notes when creating profiles:
Color
The default color model used is the Enhance default.
Global color adjustments allow for manual edits to specific color balance fields
Crop
To customize a crop, click the dropdown menu and change from "PSPA" to "Custom"
Input preferred dimensions
Move and resize the crop box on the preview photo
Click "crop" to preview the crop
Click "remove crop" to continue editing
Extract
Always select "Remove Spill" unless a PSD file output is required. When "Remove Spill" is turned on PSD file outputs are unavailable
Do not use "Turbo Spill" unless there is a harsh color spill on images
Toggle on "Replace Background" to upload a background image to be used at no extra cost
Toggle on "Dual File Output" to have both the PNG of the extracted subject and the JPG of the background replaced image at no extra cost
To use the custom profile
Create a job
On the profile drop-down menu scroll to the subhead “Account profiles” and select the one you just created.
