Working with Class Composites, Group Photos, and Team Photos
There are several ways to manage class composites, group photos, and team photos in Captura Workflow. The best approach depends on when your final images are ready and how you plan to sell them.
This guide walks through the most common workflows so you can choose the option that best fits your studio.
Before you begin
Before setting up your workflow, make sure:
Subjects are assigned to the correct Groups.
Your products and packages have been created.
Your Price Sheet includes the required group or composite products.
You're using consistent filenames if you plan to replace placeholder images later.
If you'll be delivering composites after ordering has closed, we recommend creating a dedicated product, such as 8×10 Group, using:
Product Type: My Design Product
Fulfillment: Leave blank
This allows customers to purchase the product immediately while giving you the flexibility to fulfil it later.
Tip: If you're replacing a placeholder image later, keep the filename exactly the same (for example, Group.jpg). This allows Workflow's Replace tool to update the existing gallery image.
Option 1: Your group photo is ready
Best for:
School class photos
Team photos
Group images available on picture day
How it works
Upload the finished group photo.
Assign the subjects to the appropriate Group.
Publish your gallery.
Customers will automatically see both their individual images and any associated group images in their gallery and can purchase them individually or as part of a package.
This is the simplest workflow because everything is available before orders begin.
Option 2: Your composite will be finished later
Best for:
Sports composites
Class composites
Any product that requires design work after picture day
Step 1: Create the product
Create a My Design Product (for example, 8×10 Group) and add it to your:
Price Sheets
Packages
À la carte products
Leave the Fulfillment field blank.
Step 2: Fulfil the product later
Once the composite has been completed:
Export the orders containing the composite product.
Create a Group containing those subjects.
Create a Bulk Order for the Group.
Apply a 100% discount so no additional payment is required.
This lets you begin selling immediately while giving your team time to complete the artwork.
Option 3: Use a placeholder image
If your composite isn't ready but you'd still like customers to order straight away, you can upload a placeholder image and replace it later.
The workflow you choose depends on whether customers can select between multiple individual poses.
Customers only have one individual image
Upload a placeholder image (for example, Group.jpg).
Assign the image to the appropriate Group.
Once the final composite is ready, use the Replace tool to replace the placeholder image.
Keep the filename exactly the same.
Run Orders > Tools > Reassign Images.
Workflow updates affected orders using:
The subject's Primary Image.
The first associated Group image.
Note: If a subject belongs to multiple Groups, Workflow uses the first associated Group image.
Customers can choose from multiple poses
If customers selected their own individual pose during ordering, don't use Reassign Images.
Doing so may replace the customer's selected pose.
Instead:
Replace the placeholder image in the gallery.
Open each affected order.
Edit the order and select the new composite image.
Save the order.
Although this requires a little more work, it preserves the customer's original image selection.
Which workflow should I use?
If... | We recommend... |
Your group photo is ready before ordering | Upload the final group image. |
Your composite will be created later | Sell the product now and fulfil it later. |
Customers only have one individual image | Use a placeholder image and run Reassign Images. |
Customers can choose between multiple poses | Use a placeholder image and update orders manually. |
Frequently Asked Questions
Can I use the Replace tool if customers selected from multiple poses?
Yes, but don't run Reassign Images afterwards. Instead, update each order manually so the customer's selected pose is preserved.
Why should my composite product have no fulfillment assigned?
Leaving fulfillment blank allows customers to purchase the product before the final composite has been created. You can fulfil the product once the artwork is complete.
What happens if a subject belongs to more than one Group?
When you run Reassign Images, Workflow uses the first associated Group image linked to that subject.
Can customers order composites before the final artwork is ready?
Yes. Both the delayed fulfillment workflow and the placeholder image workflow allow customers to purchase composites before the final image has been completed.
