Create Discount Codes
Use Discount Codes to Drive Revenue in Captura Workflow
Create smarter offers, automate incentives, and make more from every job
In Captura Workflow, discount codes aren’t just promotions—they’re tools to help your studio:
  • Increase participation
  • Boost average order value
  • Automate follow-up sales
👉 When used strategically, discount codes help you make more—without adding manual work
⚠️ WARNING⚠️
If you use a 100% off discount code to place customer orders, the discount code will be displayed on the customer’s invoice.
To avoid exposing an active 100% discount code to customers, use a code that expires after a set period or is limited to a single use.
Phase 1: Create Standard Discount Codes
Drive promotions, test workflows, and increase conversions
Standard discount codes are ideal for:
  • Seasonal promotions
  • Flash sales
  • Testing your shop before launch
Step 1: Navigate to Discount Codes
Go to:
Shopping Cart → Create Discount Codes → New
Step 2: Define Your Code
Setting
What to Do
Why It Matters
Code Name
Enter customer-facing code (e.g., SPRING20)
This is what customers will enter
Character Limit
Max 15 characters
Prevents errors during setup
Case Sensitivity
Codes are case-sensitive
Must match exactly at checkout
⚠️ Important:
Make codes simple and easy to type to reduce customer errors.
Step 3: Set Usage Rules
Setting
Options
Why It Matters
Uses Allowed
Single-use or Unlimited
Controls how widely the code can be used
Minimum Order
Set required cart value
Prevents discounts on very small orders
⚠️ Important:
Minimum order cannot be $0
→ Use $0.01 if you want the code to apply to all orders
Step 4: Configure Value & Scope
Setting
Options
Why It Matters
Discount Type
Percentage or Fixed Amount
Controls how savings are applied
Apply To
Entire order or specific products
Allows targeted promotions
👉 Targeted discounts help protect margin while still increasing sales
Step 5: Schedule Your Code
Setting
What to Do
Start Date
Defaults to “now”
Expiration Date
Set clear end date to create urgency
👉 Time-bound offers drive faster purchasing decisions
Phase 2: Automate Sales with Shop Credit (BOO Workflow)
Turn one purchase into the next one automatically
The Based-on Order (BOO) workflow automatically generates a credit for a customer’s next purchase after they complete a qualifying order.
👉 This is one of the most effective ways to increase repeat purchases
Step 1: Create a BOO Discount Code
Follow the same setup as above, but:
Setting
Recommendation
Why It Matters
Type
Select Based-on Order
Enables automatic credit
Code Format
Use randomized codes
Prevents sharing and misuse
Usage
Single-use
Ensures one credit per customer
👉 This keeps your incentives controlled and secure
Step 2: Create a Trigger Product
In Designer, create a product that activates the credit.
Recommendation
Why It Matters
Use a non-print product (e.g., “Pre-Order Credit”)
Keeps workflow clean
Place in a non-print category
Avoids unnecessary lab processing
👉 This product acts as the bridge between first purchase and future credit
Step 3: Attach the Code to Your Price Sheet
  • Open your Price Sheet
  • Select the product or package that qualifies
  • Attach the BOO discount code
👉 This defines what purchase triggers the credit
Step 4: Let the Ecosystem Do the Work
Once a customer completes the qualifying order:
  • A credit is automatically generated
  • It is applied to their next order
  • No manual steps required
👉 This creates a seamless experience—and drives additional revenue automatically
Key Recommendations & Guardrails
Test Before You Launch
Action
Why It Matters
Create a $0 test code
Validate products and workflows
Submit a test order
Catch issues before customers do
👉 Testing prevents costly mistakes later
Choose the Right Scope
Type
When to Use
Global Codes
Apply across all jobs
Job-Specific Codes
Target a single event or school
👉 More control = more strategic promotions
Understand BOO Limitations
  • One credit per qualifying order
  • Not supported for Standard (non-subject) jobs
👉 Plan your workflow accordingly
Product-Specific Discounts
  • Typically apply to one item per order
👉 Use this to guide customers toward specific products
What This Unlocks
When discount codes are used effectively:
  • You increase participation
  • You drive higher order values
  • You automate repeat purchases
👉 More revenue. Less manual effort.
Final Takeaway
Discount codes aren’t just discounts—they’re growth tools.
When you:
  • Create clear, targeted offers
  • Automate follow-up incentives
  • Test before launching
👉 You turn simple promotions into a system that helps your studio make more.
