Setting up a PLIC integration with Workflow
Learn how to integrate your PLIC account with Workflow to easily push your PLIC Projects to Workflow
How do I link my Captura PLIC account with Workflow?
After you've setup your PLIC account, you'll need to sign into the Master Account of Workflow. This is typically the user account of the Studio Owner.Click here to learn how to determine which account is the Account Owner.
After you've logged into the Master Account:
Open Preferences > Integrations in Workflow. You'll need to enter the valid credentials of a user in your PLIC Organization to connect your accounts:
That's it!
Start integrating your projects through Flow > PLIC> Workflow, or from Workflow> PLIC.
You'll also see your Captura Customer ID under your organization details in PLIC:
Can I pair my Captura account to multiple Captura accounts?
You can only pair your PLIC account to one Captura account as this time.
