In -app: How do I replace an order in Captura Workflow?
Need to submit a replacement order for your customer? Learn how to do just that in the online gallery or in the app with Smart Workflow
📚 Before you begin...
Do you need to create a discount code to "zero-out" the order?
  • Consider making a discount code for internal use to set the order total to $0.
Do you need to replace the order because it was the incorrect item?
  • Consider making any necessary changes to your price sheet before you begin.
Do you have a minimum order amount that's needed before completing checkout?
  • Consider swapping the shopping cart template attached with one that has a $0 minimum order amount to avoid any potential checkout issues.
How do I submit a replacement order?
There are two ways to submit a replacement order:
  • Using the Online Gallery
  • Using the Point-of-Sale system with Smart Workflow
Using the online gallery:
  1. Open subject's gallery in the browser.
  2. Complete your shopping cart.
  3. Use your internal discount code to complete checkout.
Using the Point-of-Sale system with Smart Workflow:
  1. Open the subject's record in a job
  2. Click on the Orders toggle to view order information
  3. Select Order Type to add (if applicable);
    - Add Pre-Order: Add an order for products without selecting images.
    - Add Full-Order: Add an order for products with selected images.
  4. Complete your shopping cart.
  5. Use your discount code to complete checkout; sync to "submit" the order.
    Learn more here: Creating orders for multiple subjects
