Getting Started with Image Service Fulfillment in Captura Workflow
Learn how to find and process your self-fulfilled image services, such as retouching, on your orders using the fulfillment tab in Workflow
Table of Contents
  1. Before You Begin
  2. Navigating your Fulfillment Tab
  3. Setting your download/replace directories
  4. Starting your image service fulfillment workflow
  5. Finishing your image service fulfillment workflow
Before You Begin
  • The term Image Services refers to any Retouching, Teeth Whitening or similar image-altering service. These can be lab or studio fulfilled.
  • Only studio-fulfilled image services appear in Captura Workflow's Fulfillment tab.
  • Orders with multiple service fulfillers are completed in this order:
    1Touch Enhance automated retouching is performed first (if ordered)
    Studio (self-fulfilled) services are performed second (if ordered)
    Lab-fulfilled services are performed last BEFORE printing.
  • Orders fulfilled by My Service must be released BEFORE they can be downloaded in the Fulfillment tab
  • Image Services MUST BE completed beforethe order can be digitally delivered or printed.
Navigating your Fulfillment tab
Click on Fulfillment in Captura Workflow to open a table of your ordered Image Services:
You can filter your view between statuses of complete, incomplete, and processing:
Filter by incomplete to see all orders that are waiting on studio-fulfilled Image Services before they can be sent to customers:
You can manually refresh the table using the button at the top-right of the menu bar:
You'll be prompted to set the download and replace directories used by the Fulfillment tabon your current device.
Click on Settings → Image Services in the message or the gear above the message to access the Image Services section of Fulfillment Settings:
In the Image Services section of your Fulfillment Settings. Select a directory for Captura Workflow to download the ordered image from and for Captura Workflow to upload the serviced image to the order from:
You can download the image service orders you need to fulfill using one of three methods:
  • Use the checkbox to select all or specific image service orders to download.
  • Use the download all button to download all incomplete image service orders.
  • Use the auto-process toggle to automatically download (and automatically upload) image service orders.
Once downloaded, you can begin performing the ordered image service. The images will download into separate folders in your download directory named after the image option ordered. The image files will also be named after their corresponding value in the column Image ID, providing easy lookup and order reference when needed.
When you're finished performing the image service, save the file in your specified upload directory to wrap up your image service. Captura Workflow looks inside your upload folder and processes replacementsonly if the filename remains unchanged from when it was downloaded.
Once they've been saved to the folder and Captura Workflow recognizes the file, you'll be prompted to sync in Workflow. With auto-process on, new images will automatically upload every 5 minutes.
❗You can save the processed images directly into the root of your specified upload folder. No need to add in any subfolders. ❗
