Product Designer Manual
Product Designer User's Manual and Quick Start Guide
Product Designer is a high-speed-low-drag web application used by Professional Photographers and/or Studios to upload and prepare class/school composites to participating labs for processing. Simply upload your images and data to the Captura Image Cloud, log into the Product Designer website with your credentials and drag and drop your images to arrange accordingly on your composite. You also have the ability submit directly to your lab and view the status of your order directly from the website.
This document is a Quick Start Guide for Product Designer.
Download Product Designer Quick Start Guide
This document will walk you through Product Designer.
Download Product Designer User's Manual
