PSPA Yearbook Export from School Portal
Instructions on how to generate a PSPA Yearbook Export from School Portal
When you first login as a school you will see the projects page. From there you will select Download Exports.
From there you will go to Standard Exports
and scroll down to PSPA Yearbook and click the download button.
If you have no special requirements you will click continue through the options given. After clicking continue you will see this screen which will show the progress as the export is generated.
The exports usually take a couple of minutes to generate. When it is done you can click Download to get your ZIP file containing the complete PSPA Yearbook export. No CDs required!
