Captura Yearbooks: Changing Seasons
Changing a book to or from the current season
Go to the Dashboard, and click on the Yearbooks tab on the left. Find the yearbook you want to edit, then click on the down arrow to the right of the blue Yearbook button. Click on black drop down arrow. Then click Project Settings.
Go to the Seasons dropdown.
Change it to the season you want it to be attached to, and then click Save at the bottom. Now, the Book project will be in a different season!
