Workflow orders in PLIC.io and Flow
View your Workflow orders in PLIC.IO, Captura Product Designer Reports, and Flow.
This article will cover the process of importing your Workflow orders into PLIC.io and Flow.
First, you need to contact Captura support and ask them to enable your "Captura order sync".
Once this is enabled, all future orders placed in Workflow will show up in PLIC.io. Past orders will not be here, only your orders placed in Workflow after enabling the sync will show in PLIC.io.
When, viewing the list of orders, click on an order number to see more details.
Now, If you go to Captura Product Designer, you can create a report of your orders. Reports can be downloaded as pdf or csv. You can find more information about how to create and edit reports in Captura Product Designer here.
You can download these orders into your Flow project. Open your project in Flow, Click on the PLIC icon, then select the "Online Gallery Order Tab". Then Click on "Check For Online Orders Now"... Your Workflow orders for this project will import into Flow.
And.... That's It! Contact Captura support if you have any questions.
