Managing sub licenses in PLIC
How to manage sub licenses, accounts, or studios in PLIC
After logging into plic.io, go to the My Organizations tab on the left sidebar. From there, click on Sub Organizations.
If this is a new customer, click on the New Sub Organization button. You will create the Sub Organization as studio. If this is an existing customer, skip this step and click on the studio's name in blue on this page.
You should end up on the studio's information page no matter whether you just created this studio or it already existed. In this screenshot you can see the studio has 5 app license. If a studio does not have any licenses, users, schools, etc you will need to add those. Once you click "App Licenses"> you select to add the "sub license" for the account. A sub license allows the Lab/Vertical studio to transfer licenses to their studio accounts
The license defaults to expiring 1 year from today, but can be changed both now and after it is created.
After clicking Create License, you will be on the license page.
If this license is for Captura Yearbooks or Captura School Portal, you will need to do one more step so your schools can use credits from your license. Click on Edit Details to go back into editing the license. You will check the box for "Automatically spend credits from master license when needed" and then click Save License.
From the license page click on the studio's name to go back to looking at the studio's information.
The last step will be inviting the studio to join PLIC if this is a new studio. This time you are going to click on Users.
Click New User.
On this form, you will enter the new user's full name and their email address. You will generally want to leave the Enable for all licensed Captura apps checkbox on. Those options are usually only used to limit what school users can do. Your studio users should have full access to all of the apps they are licensed for. Click Create User when you are done.
At this point an invitation will be sent to the new user's email. They will be prompted to set a new password before being able to login to Captura PLIC apps.
At this point you are done! They will be able to login on Captura's PLIC apps.
