Releasing Held Orders in Captura Workflow
Learn how to release your held orders from a Job in Captura Workflow
Before you begin:
Your Job must have "Hold order fulfillment until manual release" checked under Job Settings > Order Fulfillment. You must also have orders in your Job that have been held from fulfillment.
Learn more about releasing service items Here
Releasing your held orders to your Lab:
Open the Job with held orders and navigate to the Job's Orders tab. If your Job has been configured to hold order fulfillment and you have orders that are waiting to be manually released, you'll see a "release all orders" button:
You'll then be prompted to confirm if you'd like to send these orders to your Lab as a Bulk Order, You can also specify that the bulk order must be shipped to the studio address on file in Captura Workflow Preferences section or specify a shipping address
🚨 PRO TIP 🚨Captura Digital Downloads will always need to be individually released as they are not going to the same location.
After you've finished specifying your release preferences, you'll be taken to a final overview to summarize your order release. If everything looks good, click on the blue Release Orders button to release your orders.
As a final precaution, you'll need to manually type in the word RELEASE into the text box when prompted to finish releasing your orders
Back on the Job's Orders tab, you should see your orders now have a Release Date instead of " - ". You may need to refresh the table by clicking refresh if it has not updated.
How to Release a Single Order in Captura Workflow
Learn how to release an individual order in Captura Workflow without releasing other orders in your Job.
1. Open Captura Workflow and navigate to the Job containing the order.
2. Click the Orders tab.
3. Select only the order you want to release.
4. Click the three-dot menu (⋯).
5. Select Release Order.
 Important Note
If your selection includes a mix of released and unreleased orders, the Release Order option will not appear.
Make sure you select only the unreleased order you want to release.
