Getting Started with Pre-Order & Proof Jobs
Captura Workflow offers two primary job types—Pre-Order Jobs and Proof Jobs—to support different sales workflows. Understanding how each job type works will help you choose the best experience for your customers and manage orders more efficiently.
Whether you're collecting orders before picture day or selling images after they're available, Workflow gives you the flexibility to support both approaches.
In this article, you'll learn:
  • The difference between Pre-Order and Proof Jobs.
  • How each job type works.
  • How to configure a job as Pre-Order or Proof.
  • When to use each workflow.
  • Whether you can use both job types for the same event.
Understanding these workflows will help you choose the right ordering experience for your studio and your customers.
When creating a new job, you'll choose whether it will be a Pre-Order or Proof job.
To configure the job type:
  1. Open Jobs.
  2. Select New Job.
  3. Enable Pre-Order to create a Pre-Order Job, or leave it disabled to create a Proof Job.
You can change a job from Pre-Order to Proof later by updating the Job Settings.
💡 PRO TIP: If you're using Smart Workflow, consider using Stages to automatically transition from Pre-Order to Proof once your images are ready.
Understanding Pre-Order Jobs
A Pre-Order Job allows customers to purchase products before images are available.
This workflow is commonly used before picture day to collect orders in advance.
How Pre-Order Jobs Work
  1. Customers sign in using a Global Online Code.
  2. Customers select and purchase products before images are available.
  3. Images are captured and uploaded after picture day.
  4. The studio matches each order to the correct subject.
  5. Workflow adds the subject's images to the existing order for fulfillment.
Related Article: Assigning Subjects and Images to Pre-Orders
Understanding Proof Jobs
A Proof Job allows customers to view images before placing an order.
This workflow is ideal when customers need to select their favorite images before purchasing.
How Proof Jobs Work
  1. Customers sign in using their unique Online Code.
  2. They view their available image proofs.
  3. Customers customize their order by selecting images and applying options such as cropping or retouching.
  4. Images are automatically added to the order for fulfillment.
Change a Job from Pre-Order to Proof
Once your Pre-Order period has ended and images have been uploaded:
  1. Open the job.
  2. Navigate to Job Settings.
  3. Disable the Pre-Order setting.
  4. Save your changes.
Your job will now function as a Proof Job, allowing customers to view and purchase available images.
Using Smart Workflow Stages
If your studio uses Smart Workflow, you can automate the transition from Pre-Order to Proof using Stages.
Stages help streamline your workflow by automatically moving customers through each phase of the ordering process.
Related Article: Using Stages in Captura Workflow
Q: Can I use both Pre-Order and Proof for the same job?
A: Yes. Many studios collect Pre-Orders before picture day and then switch the job to Proof once images are available. This allows customers to place additional orders after viewing their images.
Q: Can customers choose their images for a Pre-Order after photos are uploaded?
A: No. Pre-Order and Proof orders are separate. For Pre-Orders, the studio matches the subject's images to the existing order. Customers cannot return later to select images for that original Pre-Order.
Q: Can customers place both a Pre-Order and a Proof order?
A: Yes. Customers can place multiple orders. For example, they may purchase before picture day and then place another order after images are available. This can be a great opportunity to offer additional products or promote new items from your Price Sheet.
Q: When should I use a Pre-Order Job?
A: Use a Pre-Order Job when you want to collect payments before picture day and fulfill orders after images have been captured and matched to subjects.
Q: When should I use a Proof Job?
A: Use a Proof Job when customers should be able to view, select, and customize their images before completing their purchase.
Quick Guide
Feature
Pre-Order Job
Proof Job
Images available when ordering
No
Yes
Customer selects images
No
Yes
Online Code
Global Online Code
Unique Online Code
Best used for
Before picture day
After images are available
Images added to the order
Studio matches images after upload
Automatically added during checkout
