Getting Started with Jobs
A Job is where everything comes together in Captura Workflow. It stores your images, subject data, orders, pricing, and gallery settings for a specific shoot or event.
In this guide, you'll learn how to create a new Job, understand the available configuration options, and choose the right settings before you begin.
Before creating a Job, make sure you have:
Both are required before a Job can be created.
Settings That Cannot Be Changed After Job Creation
The following options are permanently locked once the Job has been created.
Setting
Enabled
Disabled
Subject Configuration
Creates subject-based galleries where images are assigned to individual subjects.
Creates a standard gallery where everyone can view every image.
Green Screen
Supports PNG uploads and allows customers to order custom backgrounds.
PNG images are automatically converted to JPG during upload.
Settings Locked After Images Are Added
These settings can be changed initially but become locked after images have been uploaded.
Setting
Image Format
Large Format (Default): Maximum image size of 6000px on the longest side.Standard Format: Limits images to 3200px on the longest side for faster uploads.
Disable Face Detection
Speeds up image imports by disabling automatic face detection and Auto Head-sizing.
Important: Pre-Order Jobs should always use a Custom Form.
đź’ˇ Pro Tip: If you're unsure which image format to use, leave it set to Large Format. You can always optimize uploads in other ways, but image quality cannot be recovered later.
What is a Job?
Think of a Job as a folder that contains everything related to a single photography event or shoot, including:
  • Images
  • Subject records
  • Orders
  • Gallery settings
  • Pricing
  • Online ordering configuration
Any changes you make locally must be synced before they're available on your other devices.
Create a New Job
  1. Select Jobs from the navigation menu.
  2. Click + New.
  3. Enter the required Job information.
Note: There are several optional configuration pages during setup. This guide covers only the minimum settings required to create a Job.
Enter a Job Title
We recommend using a consistent naming format.
Suggested format
YEAR SEASON SCHOOL TYPE
Examples:
  • 2025 Fall ABC Elementary Underclass
  • 2025 Spring XYZ High School Seniors
  • 2025 Smith Wedding
Choose a naming convention that's easy for both your studio and staff to identify later.
Select a Job Type
Choose the option that best matches your event.
Available Job Types:
  • Wedding
  • Portrait
  • Seniors
  • Underclass Spring
  • Underclass Fall
  • Sports
  • Event
  • Daycare Spring
  • Daycare Fall
Using the correct Job Type helps:
  • Filter Jobs more easily
  • Restrict discount codes
  • Improve bookkeeping and reporting
Configure the Job
Choose how your Job will behave.
Subject
Enabled
Disabled
Creates private galleries for each subject.
Creates one shared gallery containing all images.
Supports subject records and unique online codes.
No subject records.
Supports keyword and password access.
Keyword and password access still available.
Supports Pre-Order.
No Pre-Order.
Supports Green Screen.
No Green Screen.
Supports Workflow order entry.
No Workflow order entry.
Separates subject and group images.
All images remain together.
Locked after Job creation.
Standard Job configuration.
Pre-Order
Enabled
Disabled
Customers can place orders before images are available.
Customers must verify the subject gallery before ordering.
Requires a Custom Form.
No Custom Form required.
Subject data and images can be added later.
Subjects and images must already exist.
Green Screen
Enabled
Disabled
Supports PNG image uploads.
PNG images convert to JPG automatically.
Customers can preview custom backgrounds online.
Background selection is unavailable.
Requires Background Sets in the assigned Price Sheet.
Background Sets are not required.
Standard JPG workflow.
Hidden
Enabled
Disabled
Job is hidden from the Gallery Landing Page. Customers must use a direct gallery or subject link.
Job appears in gallery searches and the Gallery Landing Page.
Manually Set Online Codes
Enabled
Disabled
Allows you to define your own unique online code when creating or importing subjects. Useful when using Student IDs or another existing identifier.
Captura Workflow automatically generates unique online codes for every subject.
Configure Images
Image Format
Option
Large Format
Default setting. Maximum image size of 6000px. Recommended for most studios.
Standard Format
Limits images to 3200px for smaller file sizes and faster uploads.
Only Show Primary Image
Displays only one image for each subject in the gallery.
The Primary Image is determined by the studio and defaults to the first image uploaded unless changed.
Disables automatic facial processing during image import.
Benefits:
  • Faster uploads
  • Faster image processing
Trade-off:
  • Auto Head-sizing is unavailable for the Job.
Assign a Price Sheet
Select an active Price Sheet.
You can browse or search your available Price Sheets.
Assign Cart Settings
Choose the Shopping Cart Template you want this Job to use.
You can browse or search your active templates.
Create the Job
Click Create to finish setup.
You'll be taken directly to the Job dashboard tab inside your new Job.
Tip: Enable Import subjects after job creation if you want to begin importing subject data immediately.
Common Job Configurations
The following table shows the most common Job configurations.
Job Type
Screenshot
Additional Information
Subject-based Jobs (Unique Online Codes)
Enable Manually Set Online Codes if you want to define your own gallery passwords or IDs.
Standard Jobs (No Online Codes)
Everyone can view every image. To protect access, set a gallery password under General > Password.
Subject-based Green Screen Jobs
Supports PNG image uploads and background ordering.
Related Articles
Q: Can I change Subject Configuration after creating a Job?
A: No. Subject Configuration is permanently locked once the Job has been created.
Please reach out to support@captura.io if you need to change a job after creation.
Q: Can I enable Green Screen later?
A: No. Green Screen must be enabled when the Job is created.
Q: Can I change the Image Format?
A: Yes, but only before images have been uploaded. Once images exist in the Job, the setting becomes locked.
Q: Why should I use Large Format?
A: Large Format preserves the highest image quality (up to 6000px) and is the recommended setting for most workflows.
Q: When should I use a Custom Form?
A: Always use a Custom Form when creating a Pre-Order Job. This allows customers to provide the information needed to match their order to the correct subject after checkout.
