Cover Design
On the book preview window, the covers appear as the first and last page in the book on your ladder.
To navigate to the front or back covers to edit them, click on the first or last page buttons at the bottom of the editor.
Cover dimensions are automatically preset based on the binding type and book size set up by your publisher. You may find one or more of the following cover types on your book ladder.
  • Hard Cover  – The book is bound with a rigid cover with a defined spine region.
  • Perfect Bound – A soft-cover binding where the cover is wrapped around the interior pages with a defined spine region. The interior pages are glued to the binding.
  • Saddle Stitched – A soft-cover binding where the cover is folded in half then stapled into the folded interior pages.
Cover guidelines
Covers display safe margins in the same manner as interior pages.
Soft Cover
Hard Cover
In the middle of the cover spread is the spine area. Saddle stitch (staple-bound) books only show a single fold line at the spine. Perfect bound and hard cover books will show a gap area. If sufficiently large, spine text may be added in this area.
Soft cover books will show a thin trim area around the perimeter of the cover. Hard cover books will show a larger shaded wrap area around the perimeter - this is the printed part of the cover that folds over the back of the hard cardboard stock. Backgrounds and banners spanning edge-to-edge should go through the trim/wrap area.
Editing your cover as a spread
To view your cover in the editor as a full back-to-front spread, click on the page setting gear in the top right corner of the page then choose Edit Spread. The back cover will show on the left side and the front cover will show on the right side.
Switching between two covers
If your school opted to offer both a hard- and soft-cover option for your book, toggle between the covers using the page setting gear in the top corner of the page.
Copying content between covers
To copy the design of one cover to the other, access the x feature under the page setting gear.
Cover Layout Options
Use a Theme to automatically add backgrounds to both sides of your cover (also applying default backgrounds to all your interior pages), or add backgrounds from option on the right-side pane in the editor.
Drag layouts to the front or back covers to get your design started, or drag an image from your candid image collection to apply to one or both sides of the page. Customize your layouts as you like, applying content from any combination of these four sources with custom text frames, clip art, additional photos, etc.
Tip: Backgrounds automatically snap to the edge of your pages. If you choose a customer background uploaded to your candid image collection, be sure to extend it to the outer edges of the canvas — don’t leave any small edges around the border as this area may appear on your finished cover.
After positioning the image to cover the canvas, use the lock on the frame toolbar to ensure the image won’t be reselected/moved when you are adding other elements to the cover.
Spine Text
Spine text may only be applied to Hard Cover and Perfect Bound books. Check with your publisher on the minimum page count require to add the spine text, since smaller books with narrow spines may not be recommended for spine text. Saddle stitch books do not have a spine area, only a fold line with staples.
If you do not find a text frame in position over the spine, access the Design Elements area on the right-side pane, then drag a text element to your page.
Start customizing the text, and rotate it to the right so it is vertical. Note that ALL-CAPS is suggested to make placement easier.
Complete the customization so that the text is perfectly centered in the spine area. It is recommended to not cover more than 70% of the spine width.
Accessing a second cover page
If your studio has set up a hard cover and soft cover option for your school, the format will of the current cover type will be displayed in top right corner in the page editor.
To switch to the second cover page, click on the page settings gear the top right corner, and click on the second cover type to launch it in the editor.
Choose Duplicate Content to copy the design to the other cover. Be sure to review both covers for placement issues!
Endsheets and Inside Covers
The first and last page of most books is usually defaulted as a blank white page that cannot be edited. This represents the inside cover. Hover over the page banner to confirm that this page may not be edited.
If your school has opted in for printed inside covers, the first and last page will be editable in the same manner as a candid page.
